Originally Posted by Leadfoot
might also help if you block the back side of the chin spoiler.
Im actually planning on replacing it with one that is going to cover the wheels better, with an additional flare out to push airflow around the tires. that will be stage 2
then I will be an attaching a belly pan that will run front to back, with maybe a couple of spots for heat to escape. looking to make it out of thin aluminum materials to keep it heat resistant and more durable than coroplast.
