Old 11-02-2010, 08:05 AM   #37 (permalink)
MN Driver
2000 Honda Insight
bennelson, One thing that should be pointed out. You said in your video that the Volt has a plastic tank. The tank is actually steel because the tank is pressurized, actually they keep the tank under constant vacuum to prevent evaporative emissions and to prevent the ethanol from having exposure to moisture which it would absorb and foul the fuel. There is a video on Youtube where Andrew Farah explains this.
