There seems to be a reasonable write up here.
Flywheel lightening & performance gains from lighter flywheels
I can't say I have noticed the effect of the lighter flywheel on hills as mentioned (I assume it means coming down hill, the engine compression is slowing the engine faster as there is less weight to keep the momentum up) but the engine is a bit of a lugger anyway.
