My travelling environment, glad I gave it a quick hoover last week
Anyone want to play spot the VAG part ? The wheel is an obvious one... Note I drive on the correct side
so the wheel is on the right, and mods seem to be at a minimum. But wait, there is an SG2 poking its head over the steering column.
Why yes, there it is. Note that the SG supplied sticky pad has long since given up so I replaced it with one intended to stick number plates onto the outside of the car, but as you can see the toxic state of my interior has made it fail.
No it wasn't as late as the clock suggests, I must work out how to change it for GMT after BST.
All of this looks neat until...
Yes I did take a Dremel to my dashboard to get the wiring to fit. I actually got fed up of banging my knee on the door to this cubby hole.
I did miss out a pic of the insulating tape holding this cover closed, but you get the idea.
