Oh, you can call them one-offs... my typical FE ranges from ~64 to ~92mpgUS.
Having a passenger and a topcase full of books makes a difference, so does rain, cold (down to mild frost), head/sidewind... Teresa's a real workhorse, I often can't choose the weather I'm riding in.
Speed is another important factor, prolonged rides at freeway speeds could bring the FE under 60mpg (once I tried it too), so I don't do it. But at ~110km/h (~70mph) she gave me ~73mpg in the summer, which I feel much better. For ~90 mpg I need hilly area, nice weather and 1-up riding, mostly low speed in highest possible gear (only a few pulses over 55mph), and much coasting (or agressive pulse&glide on the flat which can be tiring).
I'm usually 146...150lbs (plus my riding gear, of course), of course it makes a little difference. Typical altitude is 100-200m here (~330-650ft) so the air is pretty dense. It's not even easy to find any road over 4-500m nearby.
And she's another thumper, not a twin, with the same 4-valve 652cc Rotax engine (some batches are built in Taiwan though) - a little modified compared to the old Aprilia one, which has 5 valves. (Oh, wait a minute, we have a twin too and gets similar mileage, but it's a 250cc twin
As for tires, I've been using Metzeler Z6 (strictly road) since day one, it's the second set on, now at 22000km (I got the first pair already equipped since I bought Teresa used, and had them for ~21100km, replaced together), and inflated to sidewall max instead of BMW recommended.
