Old 11-05-2010, 09:17 AM   #3 (permalink)
TomEV
Ford Escort 2.0
TomEV's Avatar
Electricar - '89 Ford Escort LX Hatchback
Originally Posted by dcb View Post
Just curious, what do you suppose the resistance of that bit of nichrome is? And it is in series w/the field when engaged?
I measured the resistance of the Nichrome a while back, and if memory serves it is about .09 ohms. This gives about 10% increase in speed compared to non-FW. Some people use a short length of small diameter (e.g. a foot or two of #6) battery cable with similar results.
This is a mild amount of Field Weakening. I have considered adding another contactor in the FW system to use half of the existing resistor (.045 ohms) for more speed, but I am concerned that the extra amperage across the armature may burn out the brushes if used too much.
The resistor is in parallel with the field only - part of the current goes through the resistor, the rest goes through the field; all the current still goes through the armature.
As to the speed/FW relationship, here is a dyno run for the Citicar from a while back. The dynamometer shows that this motor puts out 10.6 hp /46 lb ft torque (417 amps @ 44.1v input) - thin green line. Field weakened motor puts out 11.3 hp and about two lb ft above stock curve - thick green line. The end of the thin green line is the RPM limit when FW is not turned on.
The strangeness in the beginning of the FW curves is a dyno data error.
Name:	Citicar Dyno Graph.jpg
The Following User Says Thank You to TomEV For This Useful Post:
mora (11-05-2010)
