Old 11-05-2010, 02:24 PM   #3960 (permalink)
sawickm
ReVolt Enthusiast
Originally Posted by adamj12b View Post
To power the vla500 you will need 15vdc. The gnd will be shared with the pwm ground so it's not a big deal. It will just require a boost converter to boost the 9-14v battery input to 15 for isolation.
-Adam
Hi Adam,
I was just looking at the PWRX BG2A reference design that Paul based his PCB from. It shows that you need +15V and +5V, the on-board opto ic's use the +5V off of pin1, and shared GND pin6. You could use the +5V off of the Controller PCB for those opto's right.
Hey, looking at other IGBT driver PCB's I found this website: IGBT-Driver - Power Electronics: Home High end stuff !!! I like the way that they mount the diver PCB right to the IGBT's and connect them to the controller with a ribbon cable interface.
-Mark
