Old 11-05-2010, 09:39 PM   #12 (permalink)
Rokeby
Gen II Prianista
Rokeby's Avatar
I'm having trouble getting my mind around the possibility of the Gen III Prius
having worse aero than the Gen II. I'm no fan of the overall Gen III shape/look,
so it would make me happy in a perverse way if worse aero went with it...
That said, I want to believe it's something else.
I take it that the roll-downs are done in "neutral"...
Well, as neutral as a Prius gets; all the bits are still connected through
the PSD, and "neutral" is just a HSD imposed/created electronic condition.
IIRC, on the Gen II, in "neutral" there is just the slightest power being used,
~0.7 HP. I'm guessing that is to overcome drag from spinning the ICE.
Could the Gen III be using a different "neutral" algorithm so that the ICE drag
isn't compensated for?
And then, the Gen III has more aggressive regen if the roll downs were done
in D, in a "blue arrows" coast.
