Old 11-06-2010, 08:45 AM   #15 (permalink)
donee
- - '10 Toyota Prius III w/Navi
Hi OM,
Yea, the Prius does that too. We Prius people run our tires at 42/40, or a little higher in general. This will generally result in reasonable tire life. I have my 2010 at 44/42 right now cold, in the morning, before the sun hits them.
The Toe-in spec tolerance on the Prius allows toe-out. Which has been the consternation of allot of Prius drivers. I agree, minimum toe in, without going to toe-out. The rear Prius alignment is only adjustable with shims.
There is a shop near by which the owner races 911's. He has 4 wheel weights capability as well.
