Old 11-06-2010, 11:19 AM   #14 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
Originally Posted by ShadeTreeMech View Post
What causes increased RR at higher speeds? Is it due to more heat buildup from tire deflection at such high rpms?
And I noticed you excluded other tires such as truck tires. The main difference coming to mind is the thicker sidewalls and tread of a truck tire vs a passenger vehicle.
My best guess is that it has to do with standing waves:
I think that passenger car tires with their increased deflection are more suspectible to this. Truck tires - in order to stand up to the miliions of miles that they are expected to last - are designed with lower amounts of deflection.
Originally Posted by Boreas View Post
Since I am an amateur at mathematics.....Is the term g ,in the rolling resistance equation.........
Actually, it's a physics thing.
g - in this context - is the translation from mass to weight. Those of us who are used to the English system have trouble when we talk about mass, because we usually talk about weight - pounds.
But those who speak metric, normally speak in terms mass - grams. To get force - Newtons - you have to multiply grams by 0.00981. For reference, accelleration due to gravity is 32.2 ft per second squared or 9.81 meters per second squared.
Originally Posted by RobertSmalls View Post
......Can you give me an alternative to CRR model?..........
Sorry, but no. I don't think there is much published that has enough data points to get a better feel for what is going on.
