Old 11-06-2010, 06:52 PM   #3 (permalink)
jttriesch
Originally Posted by SVOboy View Post
To make the conversion you should need a 5-wire wideband o2 sensor made by NGK as well as the wiring from that to the fed. p07. Perhaps this is what you're missing.
I have the P07 and the 5 wire o2! I lose power when the p07 is hooked up. Im going to replace my IACV, due to a crazy idle bounce and check the vtec solenoid. My engine has VTEC-E stamped on the valve cover. I'll re-post as soon as I figure anything out!
