The original installed distributor was set @ 20 degrees static, 13 degrees full mechanical by 2000 rpm, and 16 degrees of full vacuum advance @ 25'' mercury.
The new is set @ 20 degrees static, 7 degrees full mechanical by 2700 rpm, and 24 degrees full vacuum @ 10" mercury. I'm carrying a timing light in case there is pinging.
Steve Gibson
