Old 11-07-2010, 09:30 PM   #1 (permalink)
Nerys
Grrr :-)
Nerys's Avatar
Cherokee - '88 Jeep Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Geo Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Plymouth Grand Voyager SE
Ninja - '89 Geo Tracker
90 day: 30.27 mpg (US)
Anyone here good with LED's ?
Need some expert LED advice. I am getting some yellow red and white LED's to replace all my navigation lights on my metro with LED's
Found a great deal on some nice 1watt LED's
anyway I have to wire them. I need 3.5 v for the white ones and 2 to 2.5 volts for the yellow and red led's
anyway I found ledcalculator.net
the result I got was this
* You will need 1 x 30 ohm 5 watt resistor.
* The 30 ohm resistor is color coded: Orange, Black, Black, Gold.
* Each 30 ohm resistor consumes 4800 milliwatt.
* Total power consumed by the resistors is 4800 milliwatt.
* Total power consumed by the LEDs is 800 milliwatt.
* Total power consumed by the circuit is 5600 milliwatt.
* Total current drawn by the circuit is 400 milliampere.
* The resistor values are calculated based on the common ±5% tolerance resistors.
* Make sure to wire the LEDs in the correct direction as shown below.
* Always leave some space for the resistors to breathe. They might get hot.
am I reading this right? I am going to be dumping 5 watts into a resistor? if that is true there is no real point to going led since with 5 watts going into the resistor and 1 watt going into the led thats not much lower than just using the incan.
am I reading that wrong? if not how can I get the correct voltage and current without dumping so much power into the control circuitry?
I found some 2v and 3.3v voltage zener diodes. are they what I think they are? wire one into 13.8v car power and it will change it to 2.0 and 3.3 v ? do they consume a lot of power? DO they work like I think they do?
any help would be greatly appreciated!
