Old 11-08-2010, 11:09 AM   #7 (permalink)
ericbecky
EcoModding Seeker
ericbecky's Avatar
red - '02 Honda Insight
MIMA will get you closer. If you get MIMA, you don't need a separate FAS switch. Or at least when I installed my MIMA a few years go it was integrated into the system. Also, MIMA is amazingly versatile and I don't think you'd need a brake/clutch switch mod. With MIMA you have COMPLETE cntrol of the IMA. As much or as little assist/regen as you want, whenever you want. You can also create automatic set-points for the assist/regen that fit your driving style/needs.
Adding an Enginer PHEV kit is pretty easy. Depending on your drive this would certainly bring you towards your goal. A 2kwh kit adds 85 lbs, though. That's what is in my Insight. I also use this as a way to grid charge the main pack.
You could also consider adding a grid-charger for the IMA battery. Insightcentral.net has some long threads about that.
As far as the stock pack. Even if you have to replace it for a reasonable price. Check Hybrid-Battery-Repair for details. This is what it says on their site
"We repair Insight batteries for $750 - $1250 depending on how many internal components need to be replaced. The average repair costs only $1000."
I haven't heard of anyone making a SGCC. I think if you get MIMA, you'll have plenty to play around with.
What is your typical commute like? (distance, terrrain, etc.)
Eric Powers
Your Hybrid Battery Hero
EV Powers Hybrid Battery Service and Repair
Madison, Wisconsin
www.evpowers.com
