Thread: More On HEAT
Old 11-08-2010, 01:10 PM   #10 (permalink)
DonR
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
I'm sure your well aquainted with the use of Rain-x antifog & a squegee(sp?). I have heard that making a fresh cut in a potato & rubbing the windshield with it works like anti-fog. At least it does on the inside of a helmet visor.
I will second Frank Lee's use of a fleece lap blanket & good boots.
Here is a link to some seat heaters. I'm sure you can find out more specs.
Carbon Fiber Seat Heater by WarmSeats? and Other Jeep Parts and Jeep Accessories by 4 Wheel Drive Hardware-RH2
Is it possible to put defrosting elements onto a windshield yourself?
As for the heater systems, you could make an regulator/rectifier to convert from 110vac to 12(?)vdc. This would alloy you to use the same heating element from the wall or the batteries.
Could you make a heat exchanger to extract heat off of the traction motors & give it to whatever storage system you have, assuming coolant? Only have a pump move this coolant if it is at a certain temp. or temp. difference.
Good luck
Don
