Check the A/C clutch, with the engine running take a look down in the front passenger side of the engine, right net to the radiator, you will see a belt going around a pulley on the A/C clutch and if the bearing is bad you will notice the pulley sliding back and forth, or you can try turning the A/C on and see if it goes away or changes.
