Old 11-09-2010, 03:51 AM   #55 (permalink)
max_frontal_area
"no" to cruise control
Originally Posted by Braebyrn View Post
just set the cruise and go.
DON'T! cruise control monitors vehicle speed many times a second and adjusts it accordingliny by adding more fuel or less as needed or even decellerating via brakes, which can be a big deal in a heavy setup like yours.
i wedge my right foor between the gas pedal and transmission tunnel.
it will aslo help to be proactive and watch for hills and speed up accordingly
to build momentum, just watch for the fuzz! on the downhills get off the gas once you have reached the top, properly timed you will save a bit of gas until you have to brake... proper driving techniques can save a lot of juice on a rig your size.
