Old 11-09-2010, 10:44 AM   #11 (permalink)
bwilson4web
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
Hi,
The NHW11 traction battery is actually two banks 18 and 20 modules in series. The orange safety plug opens the interconnect between the two as does a separate relay. So I intend to preserve this safety feature in both the ReInVolt and NHW11 pack. To simplify the language, I'm going to adopt the names:
  • NHW11 pack - means the pack using the older style battery modules, the one currently in the car.
  • NHW20 pack - this is the ReInvolt pack with the newer style batteries.
My plan is to carry all four conductors between the two battery packs but via my custom, battery controller. I know there is a risk of unbalancing the NHW20 pack but I'll just have to be careful. The main thing is when I disconnect the NHW11 pack, the NHW20 pack will be 'normal'.
Now I've been looking at the IBGT vs MOSFETs and am starting to lean towards MOSFETs as the switch. The diodes on IBGT suggests that if I reverse the current flow, the diode may just keep it latched up. Perhaps I'm misreading the datasheets but I get the impression the MOSFETs are bi-directional and this is my planned operational scenario.
My assumption is the MOSFETs don't really care which way the current flows and need only a modest gate control voltage that I can provide via an audio isolation transformer into an RC filter. I'm also making the assumption the MOSFETs are without a gate bias, OFF. This means loss of the AC gate control signal should make them switch off.
The RC time-constant and gate control frequency can make the transition from ON to OFF fairly quick. By driving the AC gate control signal from an ignition switch, 12 V source, I can be assured that turning the key off and/or loss of the 12 V battery will 'safe' the system. . . . At least that is my understanding.
What I'll do is work up the MOSFET switch design and test it with some cheap Radio Shack parts. If it works as expected, I'll get some power MOSFETs and build out a brassboard for 'smoke' testing.
BTW, since I plan to use these as ON/OFF switches, there will be a very low duty cycle. My expectation is little 'heat sinking' will be needed.
Thanks,
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
