Originally Posted by bobmutch
@silverinsight2
What are the best mods out there for FAS? Is there a mod to turn your Insight headlights off for daytime use?
Here is a detailed installation guide for the same FAS device.
An Insight FAS switch install - CleanMPG Forums
I don't have DRL, so I just use the headlight switch. Try pulling up the parking brake one notch, if the DRL's go out, mod that switch.
There is a Honda recall on the high-low beam switch. FYI.
Honda Insight Repair and Upgrade Blog by Mike
