Ben if you were costing and then the next day you had a hard time starting the car then you need to get that problem fixed. You should not have a problem starting as the alternator will still charge the battery when coasting, check the grounds for the starter and to the battery if those are fine and clean it might be time to get a new battery.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
