Old 11-10-2010, 12:39 PM   #66 (permalink)
Braebyrn
seeking aero mods
Originally Posted by max_frontal_area View Post
now, to get radical, and this is something i am going to be doing to groovy
as well as one of my rabbits, is an airduct to vent high pressure air from the front of the vehicle (in your case trailer) to the very back, which will exit into the low pressure area behind it - where your tail cone is now. it should work beautifully in conjunction with your stubby cone. its an old boneville trick
used to keep old cars that had round snouts from lifting at high speeds, cept
for us the use is a lil different. the duct inside the trailer could be coroplast
and designed to be colapsible or movable so you dont loose workspace.
I wonder about the air behind the truck and between the trailer.? If I put scoops to pull the air in and then drop it out behind the truck? I was thinking about that drag.
