Old 11-10-2010, 09:17 PM   #4 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by gto78 View Post
The Intercharger is one of those devices that supposedly captures the toxic fumes that are being sucked into the intake/coming out of the PCV valve.
What's the PCV valve, and what's a CDR valve ?
So of course they use tons of testimonials with ginourmous claims of mileage increases and emissions cut in half etc.
If it sounds too good to be true, it all too often is
Let's see, a catalysed chemical reaction with hydrocarbons that isn't an oxidation (which would produce heat).
Could be a catalysed dehydrogenation - splitting off hydrogen - which then gets burned off in the ICE.
Lets see how this fits into what they claim on their website :
This reaction is endothermic (requires external heat input to keep going) - check !
It's a catalysed reaction - check ! - by metals (Platinum) -check ! - used in the petrochemical industry - check !
"Modifications to saturated (i.e. fully hydrogenated) hydrocarbon molecules" ; well, that's basicly what dehydrogenation does - check !
Slight power increase from burning the hydrogen being split off - check !
You wouldn't find (as much of) the original hydrocarbons anymore, as they'd have been modified, then burned - check !
Catalytic Dehydrogenation - Encyclopedia of Chemical Processing
At least in theory, it could work.
