Thread: Aero questions
Old 11-10-2010, 10:45 PM   #3 (permalink)
Angelus359
Aveo - '08 Chevolet Aveo LS
are you suggesting closing off the buttom completely, except for a tube to allow air that bypasses the radiator opening gap?
Interesting...
I actually had an idea of piping my air intake to assist with cooling the radiator :P
Off the filter box run tubing to the radiator, and then have it run face first into it, sucking air THROUGH the radiator
The more power you suck in, the faster the cooling... slightly
Another option would be to just use a cone air filter sitting behind the radiator with the box open and then behind the radiator have a 4 inch opening in the under coating to allow air exit.
The piping idea is a viable option.
