Old 11-11-2010, 01:39 AM   #8 (permalink)
nickdigger
Originally Posted by Cooluser23 View Post
Will that code work with V6 engines as well, or does it need to be modified for that?
V6 is no problem. The Setup parameter is "injPulsesPer2Revolutions", which is normally set to "1" if you are tapped into 1 injector. The RPMs would work the same whether you're tapped into 1 of 4, or 1 of 6, or 1 of 8 cylinders.
