Old 11-11-2010, 10:00 PM   #22 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
Seems like you would be adding wear to the main bearings of your engine by not using all of your gears when you accelerate to speed.
Originally Posted by kgwedi View Post
I usually use the highest gear possible without lugging the engine. I consider 1600 rpm to be the minimum. I used to use BSFC graphs, but found that in practice a slower turning engine and higher manifold pressure to be better. That is based on experience, and not science. :-)
For day to day driving I use 1st, 3rd, and 5th only.
For my A-B-A test I used 4th also.
Noah Webster, 1787
