Thread: weird idea
Old 11-12-2010, 04:03 PM   #9 (permalink)
some_other_dave
Originally Posted by lunarhighway View Post
untill the beginning of WW2 many fighter planes like the british hawaker hurricane where at least partly constructed with fabric covered frames.
Even by the end of the war, a lot of aircraft had fabric-covered control surfaces. They were very light and quite well-understood, because "sticks and rags" had been the construction method of choice for aircraft since they had been invented.
The fabric on all but the earliest aircraft was "doped", painted with a very tough paint/glue that set up very stiff. And the fabric still required relatively closely spaced reinforcements (wood or metal ribs that the fabric was stitched to) to keep flapping to a minimum. Anyway, the doped fabric can be viewed as a very early form of composite material, where a woven substrate was supplemented by a stiff additive. Instead of fiberglass mat and epoxy, you had cotton cloth and dope.
It's a whole lot easier to work with coro-plast.
-soD
