Originally Posted by bluejoey
I recently bought a 95 Tercel, and got 37 mpg on my first tank. The majority of gas stations in my area have E85 gas, which presumably means the gas is 85% ethanol and only 15% gasoline.
That's right.
But I'd be surprised if all the gas they have is E85
I checked my manual, and it recommends not using any more than E10.
In order to use E85, the ECU should be able to compensate for it, and the valves / valveseals should be hardened to withstand the higher burning temperatures and lack of lubing - you basically get the same valve-issues as with LPG.
Presumably this car has been filled for years with E85, since it's practically all you can get here.
You sure about that ?
E5 or E10 is normal, but E85 can't be run in cars that aren't adapted to it.
It's possible to run a car on it though (Brasil has been running on ethanol for decades).
b.) if it's also costing me several mpg.
Ethanol has less energy in it than gas, so you'd need more gallons of E85 than gas to go the same distance.
The additional fuel use is between 10-25% on E85 cars sold around here.
