Old 11-13-2010, 12:51 AM   #9 (permalink)
Angelus359
Aveo - '08 Chevolet Aveo LS
Just imagine if car manufactures had front and rear wheel covers, smooth underbody, sealed cracks, insulated exhaust for velocity, leanburn engines, unrestricted cat (not nessessary on lean burn), less than 12 degree drops on back, automatically variable (thermally variable) grill block, smooth wheel covers, self pumping tires, and intake assisted radiator cooling...
It could suck through the radiator, and have the radiator fluid be piped through the intake in small tubes back and forth for direct cooling.
Have it partially replace the electric radiator fan :P
Ugh the engineering makes me giggly
