Old 11-13-2010, 02:34 PM   #8 (permalink)
justanothernoob
SVOboy- why do you believe a major company wouldnt buy this formulation? I have analysis from a major independant oil testing firm that shows the improvements to any oil it was added to- including the synthetics. I have the science as to why and how it works in oil to reduce friction. A similar albeit much more expensive type of product has been available in the aerospace industry for about a decade or so. The real "trick" so to speak has been getting it to go into a suspension that will blend into the oil without turning it into a toxic waste product afterwards, which the stuff they use in the Shuttle does- the EPA considers it to be a toxic waste. Which is why you wont ever see that stuff on the open market. This product does not turn the waste oil into a toxic hazard. Dennis
