There were no solder bridges on my controller and what I was trying to get at with the post was that on the wiki there should not only be a disclaimer about the fuse that's obvious but about the blinking light just because it stays solid doesn't mean everything's alright with the board. The board had no overcurrent for some reason the batteries are indicative of that and had I known the board was SO critical that even if one of the components were slightly off or not operational I probably wouldn't have purchased it. Only a couple filter caps were substituted the rest were either from mouser or from you.
