Old 11-15-2010, 05:22 PM   #98 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
I have mentioned before on another thread. Zote foam. It is closed cell foam and is heat moldable and is flexible. Works best with some sort of frame under it. A glue gun works pretty well for gluing sections together. A friend of mine uses a modified tip on a soldering gun to stick them together. I wouldn't use it in frontal areas unless it was well backed up but for tail areas I bet it would work pretty well. Of course there is always coroplast. I knew a guy who enclosed his utility trailer in it and it stood up very well.
Noah Webster, 1787
The Following User Says Thank You to Varn For This Useful Post:
aerohead (11-17-2010)
