Old 11-15-2010, 09:03 PM   #23 (permalink)
dennyt
in tents
dennyt's Avatar
The Adventure Wagon - '94 Subaru Loyale Wagon 4x4
Subaru
90 day: 33.43 mpg (US)
Electro-Monkey - '11 Surly Karate Monkey BMC V2S Front Hub Motor
90 day: 694.1 mpg (US)
Thumbs up
Originally Posted by cfg83 View Post
mwebb -
The digital AFR proves what I want to know. It shows the "cold 02 sensor" go from the 0.5 signal from the ECU/PCM to a lean condition as it warms up. Going lean with the engine off is the proof I need.
I got advice from a dude that works for NGK(NTK?) :
Using heated 02 sensor in place of non-heated 02 sensor? - SaturnFans Forums
Start reading from post #23 and you'll hear what he has to say. His handle is "NGKTECH". He has run my setup for a couple of years without problems, and others have done the same. That *doesn't* document miles, but he appears to come from the harsher climate of Michigan.
Like I said, I'll take the hit if it doesn't last too long.
CarloSW2
Awesome, thanks for the link I just installed a potentiometer in parallel with my coolant temp sensor, with the goal of reduced cold startup enrichment. It works great, except that the idle bounces pretty hard when it first goes into closed-loop, so I'm thinking my single-wire unheated O2 sensor isn't warming up quickly enough.
I just ordered a heated O2 sensor, can't wait to get this in the car and see what happens. Fighting the winter blues...
