Originally Posted by WaxyChicken
Alternatively, you can make two (120?) v plugs for the car's 240v charger input.
a measure on one of the 120v currents *2 will likely get you very close to how much juice the charger pulls. Just a thought.
I tried this with a well pump It did not work, It would appear that the (mine anyway) Kill A watt uses the Neutral line to measure wattage.
