Old 11-16-2010, 12:58 PM   #48 (permalink)
mnmarcus
Todayican,
Great project. I've been thinking of a similiar design, reverse trike tandem seating hybrid for a few years, only I am thinking of a 20 something horse diesel with hydraulic pump motors. Some thought, suggestions (for what they are worth)...
Reduce frontal area. Thats part of the reason you came to a reverse trike with tandem seating. I'd say fair the wheels to the minimum, attaching them to the body will increase FA more than the drag coefficient would reduce, I'd think. I plan on trying to locate all the suspension springs etc inside the body and having the smallest cross section attachment to the (smallest) wheels I can get away with.
Reduce lift. My design based background (not an engineer) makes me FEEL that tipping the wing down-forward reduces the ability of the wing to create lift. I think we mostly think of all the air going over the car, but if we design the car for air to go around it the lift forces would diminish and neutralize each other. This could probably make the lightweight vehicle wander quite a bit in different wind conditions. I am planning on making a very smooth curve to the underbelly to at least countact the lift forces from the top of the car. It has been trying to get the aesthetics to look good for this though.
Aesthetics. I think if your making a car, why not make it look as cool as you can? If you start with a rounded-ish front that pretty much tapers back to (nearly) a point, your aerodynamics will probably be near to as good as you can get anyways. If I have to "fudge it" by making the front an oval instead of a sphere and adding some slight changes I figure it will still be pretty darn close. I'm going to slant the windshield way back too! I think it looks cooler and hey, a reverse trike has a TON going against it visually (from most peoples perspective). If you can make it look awesome, you will be happier getting into it, and your friends will think it's cooler too.
I'm planning at around 20 something hp, plus whatever I can get from the hydraulics for launch assist type hybrid. We have hills in duluth MN. What is 10 hp like in Florida?
