Originally Posted by RobertSmalls;
You many be wondering what settings to use on the Super Brain 989. You want to go as fast as you can without overheating the cells, so I chose 7A charge, 10A discharge, and I didn't need to run the battery fan, with ambient temperature at 62°F. The Insight's cells are 6500mAh nominal, I used 5mV per cell peak detection, and 0.9VPC cutoff.
I just got mine Super Brain 989 charger and I have some questions regarding settings charge/discharge.
At CHARGE state:
Battery Type NiMH
Battery # of Cells 6 Cell
Charge at mAh ????? ( I guess 6500 mAh)
Amp 7.00
Cut Off Peak mV 5 mV
Cut Off Temperature ?????
Trickle ?????
At DISCHARGE state:
Battery Type NiMN
Charge at mAh ?????
Amp 10.00
Cut Off Peak mV 0.9 V
Trickle ?????
I should do 4 cycles charge/discharge per cell with 15 min. pause between cycles, is that correct?
How long do I charge and how long do I discharge?
