I have 155/80R15 tires on my car right now. They are real BFGoodrich tires. Max sidewall pressure is 55psi and max speed is something like 140? That size is often used as front tires on drag cars so they are readily available. I bought mine from tirerack.com for ~90 each.
I had to mount them on spare rims. Nissan Altima spare rims have a DOT stamping on them and look very normal.
I hope they are Narrow enough to fit on your project. They are ~5" on the tread and ~6" at the widest point on the sidewall. Good luck.
