I'm hoping to run into a good deal on a used dump trailer for the same kind of loads (plus landscaping materials) and versatility.
You may know all the following already:
Beyond 4-whl brakes,
Be sure to check weight rating of axles. AND wheels (stamped) AND tires. Your state may require fenders over wheels as well as a safety inspection and weight tags. If tongue weight gets to 350-lbs (trailer at 3k or higher) you'll want a weight-distributing hitch (tow vehicle size or capacity is irrelevant to this). I'd check axle alignment as well. Tires should be less than 5-years old per manufacturer data at present. Safety chains must EACH control the weight of the trailer in event of separation, and a breakaway switch is generally mandatory.
Can't go wrong with a PRODIGY brake controller, or LED lighting on trailer.
I understand that cash-strapped governments are now (rightfully) going after trailers in tow, so I wish you luck in sourcing and outfitting your "new" trailer. The size and density of a whole tree can be formidable.
