Slowmover, I will check out that seat cushion and put it on my wish list.
I don't know if I will put on an airspeed indicator. I already get enough comments with the boat tail. But hey, it might happen. I just like seeing the savings at the pump.
On the weight distributing hitch, I most likely will stick with the one that I have been using. I wish I could afford the nice ones, but that isn't the case.
Varn,
The zote foam I will have to check out. You say its flexiable? It may work good where I don't need it to flex as much, but maybe to take up space too.
Aerohead,
What does yours look like? I wish I had some education in engineering. Seems like it would help with the design and construction.
Bamzippow,
I did that with the nose cone, good idea and it works great.
