Originally Posted by t vago
You can try the obvious aero mods. Air dam, side skirts, maybe a partial Kammback
Also, you could put some sort of dome on the top of your cab, to make the box a little more streamlined.
I don't think that ducting will work, though. You need to make your box a little less box shaped.
But be sure to fix your mechanicals first.
will do air dam, no side skirts as i am looking to implement a zero lift/mass airflow diffuser to work in conjunction with the relief duct. yes, dome is planned, and so is a kamm.
so, what is wrong with a duct?
oh. you mean like gettin it running :=)
