My car is damn near perfect mechanical condition, as I bought it used a bit ago, it was still under warranty, and then I had a mechanic friend go up and down over the whole thing checking it out, which then I had a dealer fix under warranty.
I'm not going to sell that. As is, I spend 15 dollars a week on gas.
Can re-engaging the transmission from neutral, while moving, be damaging to the auto transmission? Often I'll start coast down to a light, and then before I get there, it turns green again. There are a LOT of lights around here (every 2-4 blocks on all major roads, and all side roads have stopsign every block).
I live on the southern edge of chicago.
I think maybe the temperature is coming into play a bit.
Lots of short drives. I rarely drive more than 6 miles.
