Old 11-23-2010, 01:58 AM   #39 (permalink)
hotroddr
Love the vehicle! The paint job is awesome! Lowering the truck, an airdam, belly pan and diffuser should help quite a bit. Regearing might help depending on what RPM you are running at your prefered speed. Good luck with the project. I will be following this one. The lessons you learn could be applied to a lot of box trucks that are on the road!
