Originally Posted by MPaulHolmes
I'm working on something like that right now. A 6kW generator charges a battery pack, and at the same time, the battery pack is being used by the controller.
Hi Paul,
I think that would be so cool if you could get that to work !!! A DIY extended range EV would be radical !!!
Does your dsPIC controller have the intelligences to start and stop the generator during the battery charging ? Is the dsPIC controller you are using DC or AC ?
I hope that you continue to tell us about your success with that project.
-Mark
