Old 11-23-2010, 07:53 PM   #12 (permalink)
some_other_dave
None of the CRXes had lean-burn engines.
Sounds like you're getting good suggestions so far. I would guess that the tires, the ELD, and the exhaust would each cost you a little bit. It might be enough to add up to what you're seeing, but I'm not sure.
Also note that colder weather will hurt your fuel economy--the colder, the worse it hurts.
-soD
