Old 11-24-2010, 04:28 AM   #11 (permalink)
dwtaylorpdx
If not mounted vertically it can trap air, which will blow the element.
Its also about half as efficient if its like mine because there is a ball bearing valve inside that is a check valve the kind of helps it push water...
Different styles may be different though...
Dave
If it has a motor its worth playing with.......
