Old 11-24-2010, 05:12 AM   #2 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
You put in less heat at idle than when driving it.
With the cold air temps, blocking air from getting into the engine compartment is the way to go.
I'm only running around 80°C , so that's probably a bit too low as well.
What temps are you getting, Piwoslaw ?
