Old 11-24-2010, 08:25 AM   #4 (permalink)
Arragonis
The PRC.
I've been monitoring mine with the block on just in case - as noted it goes up and down. From the heater output on these cold mornings even with the block I suspect my thermostat is not opening until I finally get onto the bypass and go faster - at that point my heater output gets much hotter.
It hovers about 82-90 most of the time.
