Old 11-24-2010, 10:18 AM   #19 (permalink)
Arragonis
The PRC.
Originally Posted by 320touring View Post
shame the grill block hasnt improved mpg- i get the feeling that the cold air isnt helping.
what weight removal you going to do?
It will be in two stages. The first will be to remove the spare and toolkit, and go with a can of blow up and an RAC card - the former I have to buy, the latter I have (it came for free ).
Second stage will be to remove some seatage. At most I have two people in the car usually, me and Jnr when I pick him up / take him to school so the back ones could probably come out. Having tapped that the seats themselves when folding do not weigh very much. I also need to consider the ability to conceal stuff when parked.
I may then look at some more aero to tidy up the front bumper. I may go for a full block but as tapped elsewhere its not as cold as Continental Europe here (just wetter ) so I'm wondering about that. There is also the (extreme) option of a smoothed front end - e.g.
But that is very spendy.
For info what should my intake temp be, does anyone have numbers with a grill block in Deg C, or indeed recommendations ? Wondering if I need to put in some ducting to route the cooller air from my small opening in the grill. I'm also looking out for a PD160 intake which is larger. Some people report this improves power / FE by freeing up the breathing - I'm not so sure but if I can get one cheap enough I may try it as an experiment.
So I have many plans, little time and zero skill. Sounds like a winner.
