Thread: First project
Old 11-24-2010, 03:25 PM   #8 (permalink)
aerohead
challenge
Originally Posted by BHarvey View Post
The under body is pretty tightly packaged on the car with nothing really protruding into the flow. CD on this car is rated at .28 and it does get great mileage, but as we all know, more is better. Car is a 2011 Sonata (manual).
Hyundai has already picked most of the low-hanging fruit.If you've had a look at Ford's Probe-IV of 1984,then your aware that there is still some wiggle room on the Cd with respect to the front of the car.
Since the Sonata is as clean as it is to begin with, you're not going to see the gains as if it were a pickup.
My recent experience with the T-100 is that the nose mods accentuate the belly.
Getting the air over and around the car is better than letting it go under even if it has a perfect underside.You already have ground clearance issues so you'll have to be especially careful with ground strikes.
Your cooling inlets have also been trimmed by Hundai,so you have to go carefully there also.
For 'significant' gains you're going to have to go after the back of the car at some point.And for that to work,the sides must be cleaned up.
The short of it,is that you,or anyone else is going to have to follow basjoos' AeroCivic lead.Short of moving the cooling system to the rear of the car he has essentially tackled all the 'issues' the air had with the Civic.And as you can see he's been well rewarded.
At Cd 0.28 you have a better starting point.
The aero-mods Sticky may give you some idea of what certain mods have done for other cars and you can work from there.
It would be good to have a target Cd or highway mpg to be shooting for.
