Old 11-26-2010, 10:17 AM   #5 (permalink)
EdKiefer
Originally Posted by RobertSmalls View Post
Absolutely. You can also run it from the fan control relay.
This might be handy for selecting a load limiting resistor: LED calculator for single LEDs
yes, there few options I can think of . Since fans always work off a relay you could use the trigger wire on relay instead of fan power wire .
Another option, many vehicle use a simple radiator or water temp switch to trigger fans, this also could be used .
With all ways just need to make sure it doesn't interfere with fan operation .
