Originally Posted by MetroMPG
Any references for the unique start-stop bearings?
I'm not talking about hybrid "EV mode", eg. Honda's version where the engine rotates while the electric motor propels the vehicle on its own.
I was referring to otherwise "regular" cars where the engine stops every time the car stops (assuming proper operating conditions are met - probably temp primarily & 12v state of charge) and restart when the driver releases the brake (or uses the clutch) again.
No specific reference to any manufactureer using these bearings. Do a quick search of engine bearing and you can quickly learn that there are different materials to be used. I myself use a softer bearing then normal. I would rather use a softer bearing and replace more often then have the crank turned.
Bearings are usuall comprised of three layers each have a specific function. You can find the rest.
